Dear Abbas
You are a real artist en your field!
You did a fantastic job with that phono-preamp. Now after +100 hours, I can say that your fine construktion is lifting my systeme to another level of musical expression and I know that this part of the chain will newer be the weakest anymore. Thank’s for the ekstra good parts you used — and the 100kohm resistors. They gave good use.
Can you supply me with a high-gain preamp of the same quality?
I need more gain to my 4 watt F2a amp.
What would it be — with no compromises!?
Med venlig hilsen / Kind Regards
Mikael Kaiser Mørk
